EDITED FROM PREVIOUS POST
Also be aware that there is NO POWER LIGHT at startup, because of the OBDII configuration, this is missing on the 96-97 cars
You will still be able to enter POWER mode by mashing the throttle quickly from a stop or while driving, just without the power light to confirm this. Reacts the same as the earlier cars with the power light.
This is normal.
Originally Posted by paulmeisterpk
I've got a '96 as well. I've never seen my power light come on at startup or anytime while I'm driving. My tranny shifts normal, so I'm not worried about it at all. I just figured OBD II cars didn't have a power light.
I went out and double-checked my 96 Polo. There is no POWER light when turning on the ignition or at startup. In bright sunlight you can still see the POWER lettering on the dashboard that used to be illuminated.
I wonder if Subaru just took out the bulb in the OBDII cars. I wonder if it would illuminate the way it used to if a bulb were installed? I can't see a redesign of the instrumemtation circuit just to eliminate one bulb.
Sorry for the confusion on my part in the initial post.
1996 Polo Green LSi #216 ..138,100 miles. ..SOLD
