Originally Posted by UPnorth362
I dont see the need for the X pipe if you go with the magnaflow. The magnaflow has an internal X configuration already. The SVX has an equal firing order. I would keep each bank separate. Otherwise, that would be about the diameter pipe to use.
Just my $0.02
Yes each bank separate to take advantage of the equal firing. However the pipe size suggested should be reduced somewhat.
If tone, rather than performance is the aim, anything will do.
