Originally Posted by Trevor
...By Pass Air Control Valve and the Auxiliary Air Control Valve.
Where are these located?
Several flexible tubes are involved which deteriorate and can cause air leaks.
This is the stuff that scares me. Since the trans swap is recent, and the rest of the work was substandard, I have NO faith in how these would have been put back together.
You will be wise to get hold of a set of manuals. They will save you a lot of money in the long run. Try the wanted to buy feature here, as a first option.
Will do, THANKS!!
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
