Doesn't Subaru put the speedo sensor geared off the passenger side axle? If so, the diff gearing has no effect on the speedo reading. I've never tried a 2 wire speed sensor on a SVX so I can't tell you if that is the problem or not, but I would assume that the speedo wouldn't read at all with a 2 wire sensor.
As for the radiator hoses, I found out the hard way that dealerships and most service places don't check the hoses when swapping the radiator unless it is expressly asked for. Had a hose blow out 2 days after having a new radiator put in. Just a sign of the times we live in now...
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford ExcursionSola lingua bona est lingua mortua.
