Can someone help ? I'm still confused
I ordered new parts for the PCV system. In particular, the one I asked about before (11821, aka the "F" connector) is not a valve at all, simply a 3-way connector. So my big question is :
1) where does the top port of this F connector (hose H412172) go ?
I had thought that it went to the intake system, after the air filter but before the throttle plate. But this would create a substantial path for air to flow from the air filter through the "F" connector to the PCV valve, creating a huge vacuum leak/ high idle. No ?
Also, I've been reading up on PCV systems generally, and they all seem to have an inlet for fresh air that is distinct from the outlet to the PCV valve. My second question :
2) In our case, is the fresh air inlet via the breathers on the cylinder heads ? (If not, where is it ?)
Thanks,
Jeff
