Originally Posted by rbtlen
I am not sure what questions I havent answered.
I did not try and start the car. I hooked up the jumper cables and smelled the fusible link burning. I will double check again all the fuses
The questions were numbered for easy reference.
What you now state is the most important information you have provided to date. Please now check fuse SFB 4 as requested and advise.
The alternator wiring involves a link in the suspect starting circuit and is very likely to have been burnt out. As advised above, according to the manuals a white coded wire is involved. If burnt out this would break the starter circuit.
Check all alternator wiring and connectors for signs of damage. If nothing is visible, a continuity test is the next step.
