I found another good tire for a car (my SVX)....and again it disappears...? It either went out of business...or size died...??? Well...I ran Avon Tech M500's with good success...245 45 16 (ZR)...Supposedly made by Bridgestone...?
The thing that's so disturbing is that my old Yokohamas I thot I liked so much proved to be so noisey...when I got the Avons! [They're quiet!] ...that once I replaced a rear bearing from that noise! I realized that...after I got the quiet Avons...I was considering replacing the other rear bearing (since replacing the first didn't get rid of the "bearing" noise!...ha!).
Is there a quiet...inexpensive...good tracking...TIRE? Please advise me y'all.. .
THANKS...
BTW...I like an "oversized" tire ...but I guess I can return to 225 50 16 if u got a good one! Thanks!
Jim
1995 Laguna Blue SVX AWD L - 240K (daily driver) -
"ReBuILT" used engine at 236K miles (6/13)
2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System>
ECUTune Stage 1av1 Upgrade (from 1v4)>
ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers>
Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System>
High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers>
Driveshaft Rebuilt with C-Clip U-Joints>
15 Min MOD>
20 Min MOD .. . (2011)
