Pipes now fitted, tried and tested.
Got my self a 'professional' grade flare nut spanner (10mm) and with aid of WD40 the nuts came away a treat. Eventually got info from the parts guy at my subaru dealer, and was told the pipe is metric (as I suspected) 4.78mm, which is most likely 3/16"
Much better feel to the pedal, but you still have to use both feet
, with a complete overhaul of the brakes, seems to have helped too.
Still no 13mm nuts Mal
So impressed with this car, for a 15 year old it was like dismatling a two year old it's that fresh....says a lot about the build quaulity
John
