Originally Posted by Trevor
..........However you state that you notice a loss of fluid. This means that there could be another leak, which could well be letting in air as well as leaking fluid. You should certainly find the leak and fix it.
i noticed that there is fluid all over the power steering pump and around connected hoses....im sure if that o-ring is wore out that thats where the fluid is comming from? right???
