I don't think it has a limit switch since you can usually hear the motor continue to run after the antenna has stopped, but you're probably right in assuming that it could be fixed, at least temporarily. At this point, it sounds like there's little to lose from trying.
KuoH
Originally posted by Trevor
There is usually a relay which reverses the motor for up and down motion and also limit switch contacts which sense fully up or down positions.
