There are actually 2 crank angle sensors on the SVX, both are right under the alternator, just remove the alternator, and they are super easy to get to.
The one on the left side head (by the oil fill) is the Cam position Sensor.
O2 sensors are a little harder to get to as you have to get under the car, they are pretty easy other than the clips are difficult to unfasten from the main harness, but unhook them first, then you can use a boxed end wrench to remove them.
