I had heard that the compressor will "shutt of" automatically if their is not enough refrig in the system or if it is completely out(to prevent any damage to the compressor). when it shuts down...could this be via the fuse blowing to prevent use?
This will not cause a fuse to blow. Check the A/C belt, if it's too tight it can cause a heavy load on the circuit and blow a fuse.
