Harry:
Well said. My sentiments exactly. I think I probably drive the car a little more than 7/10 on my trackdays, but I'm certainly not good enough to drive it 10/10's. Since I'm not usually competing, I don't care that my car has a good amount of mods. I think they make the car more enjoyable. The one group I run with that does Time Trials (CART) has classified me as F Street Prepared, which doesn't seem to be a bad place to be. For NASA time trials, my car would be Class E, along with stock Integra Type R's, Nissan 300ZX- NA, Mustang V-6's, Porsche 944, Subaru WRX, e30 M-3's, etc. I have driven with some of these cars on track days, and can say I'm probably in the right place. Will try to do some NASA time trials next season. All said, the SVX is a good, predictable and fun car on the track. Not the fastest car in the world, but it's fun surprising people from time to time (WRX's and E30 M-3's especially)
Looking forward to our Summit Point SVX Track Day next season.
Uberoo:
Consecutive 0-100-0's is way harsh, don't you think?
ItsPeteReally:
I'm not racing an SVX. I'm just driving fast in a controlled environment with an occasional timed performance check.
