Harry:
I have noticed the same drop in brake fluid level, from time to time. Right now using Axxis Ultimates front and Metal Master's rear. I'm using Wilwood 570 fluid, which I put in in April, and plan to change it out before next season. Looking forward to running at Summit Point next season. Do you know of any non-marque affiliated or Subie-affiliated groups that sponsor HPDE days there?
