The cost of the track day was about $250. But I had 80 minutes of driving seat time plus 60 minutes of riding seat time. That's just about $3.00 per minute of driving time, with free riding time. If a standard AutoX day costs $25 and gives you 4 minutes of driving time, that is $6.25 per minute. But, you have to have a car that is in good enough condition to take 80 minutes of pounding. You would probably get 10-12 track days out of a set of tires, unless they are R compounds, in which case you would get less, plus you might get 10-12 track days out of a set of brake rotors. Plus, fluids should be changed every season at a minimum, and there is standard upkeep like bleeding brakes, etc, and you have to count on stuff breaking, like wheel bearings, etc. For an SVX, also, spring and shock upgrades and brake pad upgrades are a must to really be able to enjoy these tracks.
As for the RS, go to NASIOC, and do a search for XXTune. I think there is a lot of material there.
