Originally Posted by Earthworm
What you are feeling is the same effect as an open circuit.
Yes, Your absolutely right. What seems to be happening is when I put the wires back together without the shift kit all is fine, But the light won't stop blinking on start up till I cycle it through the gears and then shut it off and restart it. When I hook the shift kit back up, All seems to be fine through many start ups until I mash the throttle once while it's running, Then on the next start up the light is blinking again and won't stop till I unhook the shift kit.
I'm thinking I need to adjust it to need more throttle to open the switch. Any advice? I've checked all my connections and played with this and that and now I'm going to try adjusting the shift kit. If that doesn't work I'm kinda stuck.
