Just got back from cruising around SD. The new version is nice. Snappy and quick. The dyno shop I usually go to was closed so I'll have to try another day to get dyno time and see how the new plots look.
My only issue was with the isis valve. I removed the bypass that Tom and I put on and replaced it with a straight piece of hose. But then the car was idling at 3K. Is my isis valve messed up from the bypass or do I need a check valve in the hose?
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs!
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
88 XT6(regret the day I left her behind)
socaleuro.com They like the flat 6...
Check My New Homepage..
