Originally Posted by Jade Dragon
intersting idea. i might have to consider it. ill have to do some measurements. i think that the turbos i will get, will be small enough, and facing the correct direction to mount where i had planned... now for another issue i havent quite worked out. Will i need to run double MAF?
No you will not need to do that. You can run both intakes out of a single collector. Take a look at how a 300zx tt works and you will understand it better
