Uh, y'all are absolutely wrong regarding E85. Vehicles that are rated to use it have vast differences. Ethanol is highly corrosive and more than a few rubber hoses are required. The metallurgy of the entire engine is different.
The 'gasohol' of the '70s and '80s was never supposed to exceed 3-7%, yet many distributors kept adding more until they began receiving complaints. Then they backed it down a point or two but even that was still enough to cause problems. Usually they ended up around 9-11%. That was enough to eat the zinc from carburetors, turning them into junk. Carbs were made from base metal with zinc which filled the pores. Ethanol/methanol attacked the zinc and made the carbs porous.
Now imagine what 85% ethanol is going to do to pistons, camshafts, etc. Hoses will be the least of your problems.
