Hi, no I didn't actually check the reading on the TPS because I have a digital ohm meter and it is really kind of junk, or I don't know how to use it, I just positioned the replacement one at about center like the other one was but as I said the car runs a lot better since I replaced the above mentioned items. I will try disconnecting the battery and let is sit over night, I should have done that last night.
The battery is not even a year old and never fails to crank fast, but the remote starter works great since I put the relay on the starter wire,, and I didn't even think about checking the codes on the transmission, I will do a search on here to see how to do it,, Thanks Vernon
