Measure with a DMM or pull the relay and bypass with a jumper. Contrary to the suggestions here, it does not have to be a heavy wire. Any 16-18 gauge wire will do, since it only carries current for the starter solenoid. If you don't get 12V at the ignition switch side of the harness, then there is likely a problem in the ignition switch.
KuoH
