Originally Posted by Trevor
Using power mode would move up the shift points, as I see it, only at full full throttle.
When the power mode is on, the shift point will go higher. But it's not necessary when at full throttle, I could activate my power mode anytime as I wish, the way to do that is quickly put down some gas on the pedal no matter how much, as it's quick enough the power mode will be activated...
PS: I haven't done full throttle on my yellow one after the second swap...trying to take it easy first. (only 300miles driven) I tested it the other night...I only quickly moved down my throttle about 1/3, the power mode could raise my shift point at 5000rpm of the second gear.
Spinn360, as you said, your power mode will randomly activate. But could you activate your power mode when you want to?
