Originally Posted by oab_au
Could be the ATF temperature sensor in the trans, that is reading wrong. It will put it in Power Mode, to cool the ATF.
Harvey. ![Wink](images/smilies/wink.gif)
Exactly which and what circutry will activate this feature, which I can not find refered to elsewhere. ?
Are you saying that this will raise the shift points at all degrees of throttle opening and will as a result, lower the transmission fluid temparature to a worthwhile degree ? If so, those with Power Mode switch could keep this mode in constant operation to advantage. It is strange that this idea has not been previously been brought up here.
Trevor.
