Originally Posted by spinn360
I tapped into white wire in middle with ground on neg of battery and the car was at idle is it supposed to be off with ign turned on but car not running??
Sounds like we found the problem. Dont connect the negative on the voltmeter to the battery negative. Instead, connect it to a neutral ground, like maybe the metal bar that holds the battery in place. I bet this will fix your problem.
