Originally Posted by intelisevil
mbtoloczko can make you replacement coil springs for whatever your heart desires - Stock, Raise, Lower.
That's me. :-) See link in my signature. You can also choose from a range of spring rates. I also sell the Koni inserts. If you like, I can build up struts with Koni inserts for you. If you want OEM struts, the best price on struts that I have found is at 1stsubaruparts.com. They are always a bit cheaper than subaruparts.com. 866 528-5282. Ask for Jason in Parts.
Mychailo
Visit my locker
