Bearing Noise...???
I have what appears to be a bearing noise....apparently up front..probably driver front...BUT isn't that odd to have FRONT bearings go out...especially after replacing them less than 2 years ago? Should I buy front bearing 4 sure?....Or should I check 4 other failure?...Like axle [driver front failed twice (OEM...then rebuilt)]...Or Differential bearings...???
Please give any info u can to help diagnose this situation more definitely....
THANKS!
BTW: Is there a better bearing than stock (OEM) yet?
Jim
