sounds good, but unfortunately we can't use the WRX clutch with the legacy trans. That's if the splined shaft on the WRX trans is the same as the Impreza. I found out the Legacys shafts are larger in diameter.
"If it works, tear it apart and find out why!...... "
94 Blue L, 5-speed, converted 4wd, Clear headlights, Angel Eyes, Converted Radiator and fan, White faced guages, Cross-drilled/slotted rotors, Lambo doors ...
