Factory Trans Filter(external)..
I was reading some other threads about the filter that was installed under a dealer campaign under the battery.There isn't one on mine,and I know the so called trans issues were I guess resolved by 97,is this why?
Secondly is the line on the drivers side or pass side of the radiator the inlet from the trans,I am putting in a temp gauge and I want to put in on the "hotter" line with the filter kit I am going to install.
Thanx All!!!!!
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
