Lots of new parts!!!!
Well we just spent some $$$$ and did some needed work to the SVX. New timing belt, H2O pump, tensioner, cam & front main seals. I also installed new struts on all 4 corners(factory parts). While changing out the front struts I found that both drivers and passengers side outer cv boots were torn and had emptied all of the grease out of them all over the inside of the wheels and struts so.... 2 new front axles for the SVX as well. New tires this morning. 225/50-16 V rated BFG Traction T/A's. All that is left is o2 sensors and an allignment. Next up Stage 1 ECU and a new meaner sounding exhaust.
