08-22-2005, 05:39 PM
Thread Killah
Originally Posted by blueji
Hello from across the pond!
I've got a 92 UK supplied SVX with a recently developed slipping 2nd to 3rd, a Pal of mine told me about the adjuster on the box and after a search found this thread. Ok, it seems quite straight forward to adjust the brake band and hopefully will cure the problem as the thought of a new or repaired auto box...........
To the point, is this a normal service procedure or just a quick fix until the inevitable.
John
It is a normal service procedue and will fix the slipping from 1st to 2nd or 2nd to 3rd shift. (edited after Harvey's post )
You might also try disconnecting the resistor behind the battery to get full line pressure to see if the slipping goes away.
Locker Link
2015 BRZ Limited 6MT
