Originally Posted by Landshark
i believe Rallitek is working on a turbo kit for teh Tribeca.
i don't know what major differences there are between the 3.0 and 3.3 H6, but this may benefit SVX'ers, too.
That would be great if they get a good turbo to work. The Tribeca is running 10.7:1 compression ratio on 89.2x80mm pistons/stroke. The 3.0 also uses a active valve lift system (AVLS), per the specifications in the booklet I got. but it looks the same other than that.
Steve
