I don't believe the JDM tanny I used was a VTD, it was out of a 94 Turbo Legacy(which was probably before the VTD came out), had a EJ20T with a water to air intercooler (Closed deck block)
It was a direct bolt in (other than using the SVX torque convertor, and swapping the ring and pinion in the rear diff.
But I guess it would have had the more biased rear split...
