Originally Posted by odepaj
The air comes out of the system just like if you did a two-man job but with the brake fluid in a container it doesnt suck air back into the system.
dustin
I don't see how, unless you're not explaining your process thoroughly. If you're just pumping the pedal with the tube in a bucket of brake fluid, you're just pumping a small bit out and then drawing the same amount back in. If there's air in the system that the first stroke of the pedal doesn't get out, you'll never get it out that way.
