Even in above-freezing weather, the throttle body water is sometimes needed. The air flowing into the throttle body can cause the butterflies to freeze even when the outside air temp is above freezing (from past experience with another car). I'd wait to use the by-pass mode until the outside temperature is at least 10 deg above freezing.
Mychailo
Visit my locker
