If you have the drivers button off, do you see the brass/gold color metal strip ? (I had to take apart the whole switch box) If you do, connect the the switch module back to the wiring harness, and push down on the metal strip, does the window move up/down ? If not there might be something else wrong. If yes, then it looks like the plastic switch does not push the metal strip far enough for the window to work. I stuck a small slightly thick piece of plastic on the metal strip. This way the switch was able to push the metal strip far enough to get the window working.
PS: I PM'd you.
