Originally posted by Ciscokid
I have to add: Would 2" piping be any advantage or is 2.5" the ideal size?? Thanks
The OEM size of the tubing aft of the cats is almost exactly equal to 2.5" OD. You wouldn't want to run any smaller than that. You could run 3" if you wanted. Don't think it would improve performance though.
Mychailo
Visit my locker
