you know.....
to be perfectly honest. the only reason i did the koni/gc setup is because i wanted to lower the car. it looked so weird with the 17" wheels that i had to lower it.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!!
"Too much fun to drive!"
