1. The rear of the SVX has the appearance of being lowered. Sometimes the strut mounts can fail and the car will be lower.
2. Have the system checked for leaks. There is a diagnostic check you can do to check for errors but I can't remember where on the site it is.
3. Does your power light flash 16 times when you start the car? Check the resistance of the resistor located between the battery and the fender. If all is fine then it's possible the band brake is out of adjustment.
