Hi, SORRY, shortly after posting my son went off to a concert in Pittsburg. I can answer some of the questions to give you more information. The power steering line developed a leak way underneath, husband spliced a piece of hose on for now. I tried differant settings Heat, A/C (no fans seem to be working) No air is blown out at all hot or cold. It seems to make a slight ticking noise some where near the glove box. I did check the fuses under the hood all were fine. The others that were marked fan are resisters not sure how you check those??? The climate control button is still lit and shows outside temp when pushed. Is there any fuses inside that work the fans? I didn't notice any. If any other info would help just let me no. THANKS Diane
