Tom: I installed the one reman (Fenco) caliper last nite >> Didn't notice any difference, unfortunately! I thought I might try a new one (about $120). The new one may have the tight guide/lock pin tolerances that could make the difference (?).
I'LL LET YOU KNOW . . . . . . . . . . . . . . . . . . .
Jim
1995 Laguna Blue SVX AWD L - 240K (daily driver) -
"ReBuILT" used engine at 236K miles (6/13)
2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System>
ECUTune Stage 1av1 Upgrade (from 1v4)>
ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers>
Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System>
High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers>
Driveshaft Rebuilt with C-Clip U-Joints>
15 Min MOD>
20 Min MOD .. . (2011)
