White lithium grease IS the proper lubricant to use if you have urethane bushings.
And... Whiteline swaybars are coated in a blue rubberized plastic coating. The key is they are used with urethane bushings and lithium grease. I've never seen one bind no matter how much pressure is involved as long as they are lubricated properly.
