i think mine sounds good, but i just want....
a little bit deeper tone. i will just have to put a glass pack in and see how it sounds. my pipes come off the motor stock into two stock cats. then instead of the V i had 2.5" pipes on each side run down into another cat, dual in and dual out, then 2.5" piping the length of the car and where eventually they run into two magnaflow mufflers and then finally out the back with thermal tips. it looks really smooth, very free flowing. i may eventually replace the two stock cats with higher flowing less restrictive cats. anyway my magnas have a lifetime warranty so replacing them would be silly. again i may just try the glasspack.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!!
"Too much fun to drive!"
