Autoseatbelts Fixed!
I know there's alot of people out there that have the common, "gotta open the door before you turn the car off, or the seatbelts wont retract problem." And while searching have found very little advise on how to fix it. Well fixed mine after 2 months of tinkering, and the solution was.................drum role please.............a loose connection!
There's a 4 wire conenction directly below the seatbelt motor. Even though there's a "lock tab" to securely hold the connection together, there's a lot of play in it. The instant I pushed the two conenctions together, the seatbelts fired. Doesn't seem like they have been messed with, just looks like the connections were a poor engineering build. Zip Tied the connections together and the seatbelts have been working perfectly for a week now. NOW GO FIX YOUR SEATBELTS
