JDM Legacy BG VTD tranny in EU VTD SVX - binding
Hello,
I'm facing rather expensive (so far) problem with my 1995 (1996?) Subaru SVX, originally equipped with VTD transmission. When it failed I swapped it for TZ102YBABA-CF transmission from JDM Legacy GTB (4.44 final drive). I kept EU SVX TCU originally mounted in the car. Car runs and doesn't throw any errors, but there is a binding when doing a slow turns (eg. three-point-turn). It was happening like that for two years since the swap with everybody saying "that's how it works with LSD rear diff" but now (after one diff gave up) I know it should not. The same thing is happening with new diff (4.44 of course, with VLSD). Slight whine can be heard from the diff during "lazy" acceleration. Old diff was whining like crazy on deceleration, and I want to avoid frying another diff or tranny. Transmission looks to be more or less identical to SVX one, with one visible difference - (front?) speed sensor. EU SVX has two-wire one inside a tranny, and Legacy GTB had a two-wire one but on front bellhousing. What I did was wiring these two wires to original SVX loom in place of internal sensor two wires. No idea if it can work like that, though - maybe number of rotations internal sensor in SVX measured is different than rotations Legacy-type external sensor counts, and that is causing VTD/Duty C to operate improperly, resulting in binding? I would like to check what each sensor measures, but I cannot connect to TCU through SSM - at all. With RS232 adapter I connect to ECU just fine (JECScan, sending commands manually) but all TCU returns to me is just some gibberish/trash data. I also modified value in TCU code setting it for 4.44, just as b3lha advised in this post: http://www.subaru-svx.net/forum/show...38&postcount=9 Car seemed to shift better after that change, but binding was still there. Also it hadn't fixed my speedometer being off by about 20-30% Another option is that Duty C Solenoid / valve "simply" failed in this tranny, but before I make sure sensors measure correct speeds I don't want to do it. Finding a matching (JDM) part and someone who will replace it for me in Poland won't be easy. Anyone can give some piece of advise, or helping hand? |
Re: JDM Legacy BG VTD tranny in EU VTD SVX - binding
What year Legacy is the transmission from? It might have slightly different electronics/programming. Would it be possible to obtain the TCU from the/a same car the transmission is from?
https://legacypic.uk/transmission/se...ode=tz102ybaba It's 93-96 transmission. I think it came from around 95-96 car, but have no way to make sure. Regarding the TCU - I have one which I believe is from the donor car. The same binding on tight turning problem is happening when using it, also speedometer doesn't work at all with it (which is caused by, I believe, Legacy having speed signal conversion in speedometer cluster). Apart from that it seems to shift smooth and fine, similarly to the SVX one I "modded" with FD variable change. |
Well given the year of the trans I would think it's ok to use. And if both computers result in that binding feeling, it's probably safe to assume the duty solenoid C (awd) is to blame. If I recall correctly, I don't think replacing a solenoid is too difficult, although you'll have to drain the transmission fluid and get yourself underneath the car one way or another.
On the other hand, theoretically I used the right Legacy TCU and VSS and it was still binding, but maybe wiring on SVX was wrong... but it makes no sense. |
