How much $ have you put into your SVX?
I thought this would be helpful for those who are new owners or those who are thinking of buying an SVX.
Up to date I have spent over 24K since 2004! It sound like alot, but it averages around $225 a month. This includes the purchase price, maintenance, repairs, replacement parts, upgrades and labor. |
Re: How much $ have you put into your SVX?
I am thinking mine is like $9,000-$10,000 if I include the body work, upgrades, repairs as well as the various wheel and tire combos. I have had the car a little over 5 years. Over the past few years it has been mechanically solid not requiring repairs (other than the bodywork) Years two and three required many repairs as I addressed the leaks, failing sensors and transmission failure.
Since buying the polo in 2002, I have a little over $22,000 invested.
This also includes the purchase price of the car, general maintenance over 14 years and 92,000 miles, and all the items listed in my signature. That's $130.00 a month. . |
Oh god you don't want to know... I have a spreadsheet around somewhere that tallies it up, but suffice to say I've probably spent more on the SVX than my Spec B cost me to buy.
car- 900$
title/reg- 110$ tires/wheels- 1300$ gaskets+timing+water pump+plugs- 750$ radiator- 200$ brakes- 300$ rear wing- 240$ rebuilt SMC engine- 900$ snow tires- 280$ manual transmission thats not even in the car yet- 1100$ pedals, shifter, oil cooler- 120$ belts, hoses, oil, regular maintenance left out. |
Ballpark figure is about $40K.
It would break down to around $30K for the original new car purchase and about $10K in upkeep (power steering pump, axle boots, A/C refit, transmission replacement, trans cooler & filter, sensor replacement, power window assembly, windshield, struts, tires) over 20 years. So that's about $2000/year over the life of the car, not counting routine maintenance. |
Car: $2400
Tune up (Plugs, belts, fluids, PCV, and hoses): $700 AC check, seal, and recharge: $100 Engine Mounts:$200 Valve Cover Gaskets: $300 Front Brake calipers: $170 Front Brake rotors: $200 Ball joints: $250 Tie rod ends: $170 Left front axle: $140 Struts and mounts: $1000 Power steering Pump: $150 Exhaust resonator Delete: $30 Power antenna:$25 Hood Struts:$40 Lightweight crank pulley: $180 15min mod: $30 Nevins Rear Swaybar: $260 Cromoly Teflon/ Kevlar rod ends for rear endlinks: $40 Wheels and tires: $1200 So $2,400 for the car and $5,200 in parts and labor so far. Total:$7,600 Got the car in Feb of 2010, so I have had it for almost 4 years now. So $1,900 a year, or $158/mo. |
Car Price: $1,000
Modifications/Maintenance (Oil changes NOT included): $5,770.81 Wiring Modification V.4- $75 Rally Armor Basic Mudflaps $25.35 Polyurethane 80H F/R swaybar bushings + Rear Differentail Mounts $110 Mcmaster car 4138T57 Hood Lift supports-$42.99 Cross drilled & slotted discs w/ ceramic brake pads F/R- $170.03 12V 3A 16mm Red Symbol&Circle LED Black Metal Switch-$5.69 10x T3 Red Neo Wedge SMD LED Light Instrument Cluster-$12.99 10Pcs T10 168 W5W 5 SMD 5050 Red LED Car Wedge Tail Side-$4.49 10x T5 74 Red 1-LED DASHBOARD CAR LIGHT BULBS-$1.99 4pcs 32MM SMD 6 LED 3021 3175 Festoon Dome Car Light Lamp-$5.98 Goodridge SS Brake Lines- $83.50 Hayden Transmission Oilcooler Flex-a-lite $28.99 ECUtune 4.44 TCU $230 Clear Corner JDM Lights- $155 Quickchange-$140 Halo Prosport Gauge $61 Clear Corner JDM Lights- $180 Rear subframe $15/15Min Mod- $12.75 (2) N62/Z32 Nissan 95-96 300ZX TT-$70 (8) 370cc side feed injectors- $175 Velox Wheels- $600 GMAX AS-03 225/45/R17 $425 Perrin lightweight crank Pulley- $95 Passenger OEM Inner Door Panel Cover- $9 OEM Cup Holder -$9 F/L wheel well- $40 JDM Fuel Pressure Regulator $22.95 Waterfall Grille LED- $18 MAF- $67 Front Driver side & Passenger side CV Axle- $150 2 Rear Hatch Trunk Lift Supports- $65.90 Stereo Cage + Passenger Side Sunvisor-$55 4.44 tranny swap + rear differential LSD- $800 AWD Transmission Linkage-$1000 VSS1 &VSS2- $240 Used Door sills-$64 Water pump + Timing belt+ Hydraulic Tensioner+ Idlers + 2 accessory belts (a/c, alternator) -$260 Optilux XY Yellow Fog Lights H3-$15.04 DDM HID 9006- $32.50 95 Subaru SVX owners manual-$69.80 Drivers side seat adjustor-$15 Tint Windows- $80 Lexani LX9100 225/45/R17 -$300 Owned it for 5 years $1,354.16 / Year $112.84 / Month |
I stopped counting so I don't make myself depressed....:(
I probably I know within just the car and 5spd swap put me close to 5k alone. Edit: didn't realize this was a year or so old. |
Had mine almost exactly one year.
Battery $400.00 Thermostat and Anti freeze $80.00 Rear bearings and front CV boots $820.0 1300.00 About $110.00 a month. Cheap entertainment.. I'd budgeted $300.00 a month, so it's obviously time to either break or upgrade something! |
Wow some battery.
Spent $400 on a new MAF bought new rims and tires Craig's list $400 Front and rear brakes ( Rotor, Caliper and pads) $325 HAd the car for 4 years next week. $1,125. By 4 years less than $300.a year. |
This year alone. |
Too much. Not enough. :rolleyes:
10K no joke over the years ive had it
