Crank Sprocket interchange
Does anyone know if an EJ22 or EJ25 (or any other Subaru) crank timing sprocket can be used in place of the SVX one? Thanks.
Re: Crank Sprocket interchange
If you are referring to the one that the timing belt uses, than no. The SVX timing belt is wider than the other motors so the sprocket on the crank is longer to accommodate it.
I may have one if you're needing one.
