Ac pressure switch
So got the system charged and no leaks. But the compressor won't engage. You can jump it and it comes on just fine. But went thru and checked all the wires and connections and all are good. I believe it's the pressure switch next to the condenser. Is there any way of checking it to see if it is bad?
Re: Ac pressure switch
hold the off and auto buttons down then turn the key on, all the lights will flash on and after a while it will display codes in the temp display. if it has codes it would make it much easier.
Thx tried that no codes. But i noticed yesterday the freon dye is leaking thru the pressure switch around the connection pins. So gonna assume it is bad.
There was a 94 at the junk yard. Pulled the pressure switch form in looks like a new one :) |
