Driving that 4EAT
4EAT is immensely expensive to repair in Norway. How can I drive in order to minimize wear ?
Where I live it's a lot of 60-70 km/h zones, bends, up- and downhill. After only a few days with automatic, I find myself engine breaking a lot in 1st and 2nd gear. Does this means extra wear or is it of no concern? During urban driving, is D the better option or maybe 2 or 3? Is it better to actively use manual mode in fluctuating situations or let it run itself? Edit: On eurocars, apparently the water pump runs a channel to the transmission, probably for oil-to-water cooling and it's well under 15 degrees celcius here most of the year, I don't think an additional cooler will help.. but please correct me if I'm wrong. |
Re: Driving that 4EAT
I think best way to keep the tranny in good shape is to change oil and filter
regularly. And also when you stop the car for redlight etc you sould put in in N. And not let the transmission go when you are staning on the brake over time. |
I thought the extra water pump line on the Euro cars was for an oil cooler for the engine? If it's for the trans, that's good, but I'd double check that. |
Another easy thing to do is to switch to synthetic ATF like Redline or Motul. Do a drain and refill, not a flush, about every 12k miles or 20k km.
Yes, I'll try 3 in speeds under 45 mph, the drivetrain feels a bit unsetteled under that. I'm not sure whether this is a real phenomenon or if I can actually just hear the engine due to low tyre noise (I'm on spikes now).
I'll stay away from manual mode. Just recently I went slightly uphill on pure ice that was slightly melted (in D and maybe 12-15 mph), not even a hint of spinning. Impressed my friend. So engine breaking is all cool. Use Neutral when at stand still. I'll use synthetic next time I change fluids. And city driving? |
I keep mine in 3 when driving around town, and only put it in D when I get on the highway.
Hmmmm.... why do you guys shift into neutral while standing still?
None of the clutches are applied - the input shaft still turns... I remember an issue with the 4speed ZFs in Range Rovers, Volvos and lots of other vehichles. A seal passed a little bit of flow to the A clutch apply piston and the relief drilling was too small causing burning of the said clutch while in neutral. If you are standing still in first gear all rotating components are still - no slip. The only thing is the converter is producing a little bit of more heat compare to being in neutral. Any comments? Tapani PS I think only the JDM VTD has the 3,7 gearing. |
I think all the VTD trans have 3.7 gearing. I'm only about 90% sure, I will wait for someone else to weight in. |
I read somewhere that sitting in D is better than N for gas consumption. Something something Injectors sending less something something.
How come we don't have a japanese resource at Fuji to answer all these questions for us? We should contact he japanese SVX guys and hear if they have a contact.
The outside Japan Subarus are sales and service people, there's no information threre. |
Is engine braking that bad for our cars? booooo
