-   General SVX Babble (https://www.subaru-svx.net/forum/forumdisplay.php?f=2)
-   -   Anyone have a decent aftermarket source for OEM lugnuts? (https://www.subaru-svx.net/forum/showthread.php?t=58903)
drivemusicnow 12-20-2011 12:38 PM
Need them to put the stock rims back on and I only have like 6.
icingdeath88 12-20-2011 12:58 PM
Re: Anyone have a decent aftermarket source for OEM lugnuts?
I found a big bag of them in the garage the other day if you want me to send you like 14 of them. They're not in perfect shape, but not bad, no paint or anything. Like $10 plus shipping?
LMK by PM since I'll be out of the house all day, but PMs go to my email, which goes to my phone.
Crazy_pilot 12-20-2011 01:20 PM
Just buy his ^^.
OEM style are hard to come by in our fitment. Toyota uses the same type, but they're 12x1.5 studs.
drivemusicnow 12-20-2011 01:44 PM
I'm going to try and buy them from icingdeath...
However, for the rest of you that find this thread and are upset that it was not helpful...
I found these http://www.summitracing.com/parts/SUM-7540080/ which should work.
Basically, 12x1.25 and "mag" or flat seat with shank will work with the oem wheels.
Crazy_pilot 12-20-2011 02:18 PM
I don't know about those... Have you measured the shank length on the OEM lug nuts? Those might be too long and not allow the nut to tighten down all the way.
1986nate 12-20-2011 05:36 PM
I also have a bag with probably near 100 lug nuts...
Hocrest 12-20-2011 06:09 PM
Nate loves to brag about his nuts... :rolleyes: :)
sunvalleyray 12-20-2011 09:48 PM
That is funny!
shelfy 12-20-2011 11:06 PM
I can has purchase of one?
1986nate 12-20-2011 11:14 PM
Shelfy, I'll be back "home" tomorrow afternoon. Send me a text or fbook message in the evening after 7 or so central time to make sure I remember.
shelfy 12-20-2011 11:32 PM
K. Postcount +1
drivemusicnow 12-21-2011 08:07 AM
The stock lugnuts have a shank length of ~.65 inches, the washer then is ~0.11 inches thick. These SummitRacing ones are .75 inch long bolts should work as they are, but you could always use two washers with them, and/or grind the tip down if you're finding that they don't sit all the way flush.
Obewon 12-21-2011 09:03 AM
Can I acquire 20 from you ?
Huskymaniac 12-21-2011 01:59 PM
These should work too then, correct?
http://www.summitracing.com/parts/SUM-7540081B/
kjoyes 12-21-2011 05:26 PM
i would go with http://www.gorilla-auto.com/ these they are a good product and a good upgrade.
http://www.gorilla-auto.com/lifetime-lug-nuts
