Exhaust Manifold torque
So I am completing my build, putting the exhaust back on, and need to know the torque for the nuts that mount the exhaust to the heads, and the bolts that mount the secondary pipes onto the manifold. I looked everywhere but I never have luck with the search function here. Thanks guys.
Re: Exhaust Manifold torque
Manifold to head is 25-33 ft-lb
Exhaust to manifold is 22-29 ft-lb Glenn |
I have this list tacked to the shop wall.:o
Since you already have the answer this could not hurt. http://www.subaru-svx.net/photos/fil...iles/44342.doc |
Glenn |
Glenn, would you happen to have the torque values for the engine mounts to the block, and the bushings to the mounts? Also the bushings to the crossmember? I really need to get some FSM's. :lol:
Sure Cam,
Front engine mounting bracket to block is 14-25 ft-lb. Cushion rubber to X-member is 40-61 ft-lb Cushion rubber to mounting bracket is 36-51 ft-lb Hope that helps! Glenn |
Cool!! Good luck with the project!
Glenn :cool: |
